how to turn on roaming there is no "My Services"
Mark Swindells
it says. “To check that roaming's activated on your account, log-in to the iD Mobile app or My Account online, go to 'My Services' then 'Roaming'. If it's off, toggle it on. “ however when you go into the account and into the mobile app there is no tab that says my services.
I had no calls, no data, no usage of my phone while I was recently in France, it only worked if I was on Wi-Fi.
Best answer by MalcK
Log in to iD app.
Small icons at bottom of screen.
Select    'Plan'  icon
Next screen scroll down screen to see 3 choices, middle one is 'Manage your iD Services'
Select that and choose your options.
You might also need to turn on Roaming in your phone settings.
Good Luck
  • 12380 replies
  • May 8, 2024
Unfortunately @Mark Swindells, it seems a lot of the online documentation still refers to the ‘old’ iD app and iD account online services.
The project team seem fully occupied with sorting out issues with the ‘new’ iD app and iD account online, so documentation might be playing second fiddle.
  • Helpful
  • 40 replies
  • May 8, 2024
Log in to iD app.
Select    'Plan'  icon
Good Luck
  • Helpful
  • 40 replies
  • May 8, 2024
Have you logged into iD mobile app?, not Community.
  • May 13, 2024
Hi @Mark Swindells,
Please let us know how you get on with the information that @andewhite and @MalcK provided.
