Huawei Smart Pro when will it be back in stock?
Best answer by Ryan
View originalHuawei Smart Pro when will it be back in stock?
Best answer by Ryan
View originalHi
If so, do you have any particular preference on colour? It looks like this might be an end of life product in all honesty, but we can double check for you.
Â
Rory
HI Rory, yes sorry that was the one. I'm not fussed on the colour. I've just purchased the Huawei MatePad Pro so I want to stay with Huawei for my upgrade as the phone instantly updates the MatePad.Â
No problem
Â
Rory
We’re just letting you know that we’re still waiting to hear back from the team but we will be back in touch here as soon as we find out.
Kind regards,
Â
Unfortunately our colleagues at the warehouse are taking their time getting back to us on this. We are checking it every day for you and will let you know as soon as we hear back, I’ve just this minute sent a chase up to the existing escalation.
Â
Cheers for your patience.
Â
Will
We have heard back from the team and unfortunately we will not be receiving further stock across the Huawei line of devices. Sorry about that!
Awh that's a shame as I really liked ID Mobile. I'll just need to move to another company. Thank you so much for your continued follow upÂ
The other option is you can buy the phone outright and swap to a SIM only plan with us if you wanted.
Â
Unfortunately my screen has cracked that's why I was desperate for an upgrade to replace it otherwise I'd just have stayed with the phone I haveÂ
