i have no signal in home or out and about its shocking
  • June 29, 2026
  • 12 views
Since moving to this network I can never make a quick call , my call cuts off and searching the internet is definitely a slow timing experience, my calls don’t connect
    Same.no coverage ,no sim
    Hi ​@Joannakk and ​@Lhank,
    We're sorry to hear about the issues you've been experiencing with your coverage.
    We appreciate how frustrating it can be when the service you're receiving doesn't match what you'd expect, particularly if the coverage checker is showing strong coverage in the areas where you're having problems.
    As a first step, we'd recommend checking the coverage checker again to see if there are any reported issues or maintenance affecting the locations concerned: https://www.idmobile.co.uk/help-and-support/coverage-and-networks/network-coverage-checker
    If the issue persists, please contact our Live Chat team so they can investigate further and check whether there are any network-related issues affecting your service: https://www.idmobile.co.uk/live-chat
    They'll be able to review your account and discuss any available options based on the outcome of their investigation.
