I continually am losing signal in areas where that never used to be a problem. Do I need a replacement SIM card?
i keep losing sinal
Best answer by Kash
You can check the network coverage and network status at the link below:
If you don’t see any issues, please test the SIM in a different handset.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
