I phone Voicemail
  • June 24, 2024
  • 534 views
Apple has the voicemail section on the calls app which allows you to see your voicemails and play the recordings without having to call your provider. With my old provider this worked fine, now with ID mobile there is no access to this and the only way I can hear my voicemails is by calling. Is there a way to set it up so it works as it should on an IPhone ?
Unfortunately @josiemfcrane, iD Mobile don’t support visual voicemail, so this service isn’t available on your iPhone while its using an iD SIM.
  • 12418 replies
  • June 24, 2024
