I want to give 30 days notice (on my 30 day rolling contract) AND transfer my number to the new supplier a day or two before the 30 days is up.
Best answer by Michelle H
If you want to take your number over to a new network provider, please select leave and take my number (PAC), you will be issued a PAC code, the code is valid for 30 days.
You need to give your PAC code to your new network provider, once done your iD account will disconnect.
If you do not want to keep your number, please select end your iD mobile plan. Your account will disconnect after 30 days.
Please let me know if you require any further help.
Michelle
iD Mobile
