I will be in New Zealand for 15 days. Can I buy a 10d add on then a 5d one to cover the period
international roaming
Best answer by Kash M
You certainly can, please wait for the first add-on to expire before buying another.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
