Iphone 14 not making or receiving calls
I can neither make calls nor accept them until I restart.  I’ve tried resetting network and it works for a while then stops and I have to switch off again. I’ve noticed that it happens after using AirPods but aren’t sure if there’s a correlation.  Any help would be appreciated
  • 8408 replies
  • March 11, 2025
Hi ​@JaniceL65
It’d be quite strange for your Airpods to be interfering with your ability to make/take calls.
What happens when you try to make a call while having this issue?
Is the issue just calls? Texts and data okay?
  • March 11, 2025
Hi Tom,
I have to keep switching off my phone several times a day as I’m unable to make or take any calls. As soon as it’s rebooted the calls a fine for a short time. It’s always ok for WhatsApp calls though.  It maybe nothing to do with my AirPods however, it seems that after I’ve used them, I have the same issue.  It could be coincidence .
  • 4297 replies
  • March 12, 2025
Hey there ​@JaniceL65, sorry to hear that.
If you believe the AirPods to be causing or having issues, you’d need to contact Apple directly regarding that.
What iPhone do you have and what’s your full postcode please?
How long has this been an issue for?
