iphone xr roaming issues
  • February 23, 2025
  • 6 replies
  • 58 views
Steven Walker
Really hoping that someone can help.
My daughter is traveling to Italy with school and we took her ID mobile sim and put it in an old iphone xr to save her new phone
Sadly her roaming is not working and I am really keen to get this sorted for her.
I have talked her through doing a network reset, phone reboot and then manual selection of network and none of these have solved the problem.
When selecting a network she says 4g appears and then disappers..., can anyone help as I am troubled that I can’t fix this for her.
I am guessing that the apn settings are incorrect but this isnt an option with idmobile on iphone
MZone
  • 1204 replies
  • February 23, 2025
Is data roaming toggled on the phone? Is roaming toggled on under manage services in your iD online account options? Make sure she is using TIM S.p.A, Vodafone Italy, or H3G S.p.A. to roam on.
Steven Walker
  • February 23, 2025
Many thanks for replying!
90% certain that she has roaming on and I have confirmed that roaming is active on the account
She has been able to manually select a couple of networks but says that the 4g symbol pops up and then disappears
MZone
  • 1204 replies
  • February 23, 2025
She should have had a welcome SMS also to confirm she is roaming.
Forum|alt.badge.img+21
  • 2215 replies
  • February 24, 2025
Hello ​@Steven Walker
Thanks for getting in touch.
We are sorry to hear your daughter is having trouble getting connected.
As 4G is appearing, it sounds like she is getting a connection which is good. Has she been able to try all available networks as some may be stronger than others in the area she is in?
Is she able to test her SIM in another persons handset to see if it works at all?
Nat
Steven Walker
  • February 24, 2025
Hi natalie
thanks for your message, unfortunately they have limited time and I don’t think anyway of changing sims.
i have purchased a prepaid eSIM and that is up and running for her so she is online again for the rest of the trip.
  • 2215 replies
  • February 25, 2025
Thank you for your reply ​@Steven Walker
We are sorry that she was not able to get the service running.
Please do reach out if you have any further questions.
Nat
