Is Id mobile down?
  • January 23, 2025
  • 1569 views
  • 10 replies
I can't make outgoing calls and can't tell if incoming works either because my partner is also with Id mobile and can't call to check as she can't make outgoing calls either!
  • 12413 replies
  • January 23, 2025
Apparently, there’s a network issue, ​@Hoppy2m
  • Helpful
  • 17 replies
  • January 23, 2025
Nationwide problem with Three (and ID mobile uses their network too)
  • 4543 replies
  • January 24, 2025
Hey there ​@Hoppy2m, we're aware of a network wide issue that was affecting services, and we believe this has now improved for most customers, so please restart your phone and attempt to call. We sincerely apologise for any inconvenience caused, and really appreciate your patience.
Updates can be found here:
https://community.idmobile.co.uk/contacting-id-183/we-are-aware-that-some-customers-are-experiencing-issues-making-and-receiving-calls-72269
