Issues
Rich Wildsmith
Couple of issues over the past couple of months that I’ve never encountered before.
Firstly outgoing calls are taking 15-20 to connect.  Just silence before the other line starts ringing.  Not a major issue just a bit odd
Secondly and more importantly; text messages are failing to send.  I send them and then get a notification that it’s failed to send.  Only way I’ve found to get round it is to turn off WiFi and use the data.  Any other solutions?
iphone 13
Best answer by Tyler
Hey there @Rich Wildsmith, we’re sorry to heat the issues are still persisting.
Have you checked the below coverage, and network status checker to see what your signal should be like in your area, or if any issues are impacting your area currently?
Coverage checker:
Networks status checker:
https://www.three.co.uk/support/network-and-coverage/coverage#tabs-c2d0d12ce8-item-2988999184-tab
Have you also tried resetting your network settings?
Kind regards,
  • 12248 replies
  • May 16, 2024
Perhaps the issue with sending text messages is something to do with the Apple iMessage app and service, @Rich Wildsmith
iMessage will prefer Wi-Fi if that’s available, if not then it uses your mobile data connection, and if that’s not available the text is sent as an old-fashioned SMS.
  • 8192 replies
  • May 21, 2024
Hi @Rich Wildsmith,
Just checking if you managed to resolve your issue.
If you still require further assistance, please let us know.
Rich Wildsmith
No I’m still having the same issues. Text messages unable to send.  Calls taking a while to connect.
Called the wife yesterday.  Took about 15 seconds to start ringing.   Went to answerphone.
when I got home she hadn’t missed any calls.  So I now have to use WhatsApp to call her.  We’re both using ID Mobile.
We’ll have to look to switch to another network
  • 3991 replies
  • May 22, 2024
Coverage checker:
Kind regards,
