Leaving within 14 days & PAC code use.
Hello,
I recently started a phone and SIM card contract with ID Mobile. Unfortunately, I’ve had to to return the device within the 14-day cooling-off period due to patchy reception where I live. The customer service team provided me with a Return Transaction Number and the necessary details for sending the phone back, all good.
I also requested a PAC code and received this automated message:
Hi *****, your PAC is ****** and it expires on 31/05/2024. To switch your iD Mobile number to your new provider and disconnect your iD plan, simply give this PAC code to your new network before it expires. Your iD Mobile plan will remain active, and you will continue to be billed unless you use this PAC before the expiry date. If you use your PAC today, your estimated final bill will be £517.92 (excluding any unbilled amounts).
I know that is a standard message for someone under contract, but I’m a bit wary about being caught out on technicalities. I have a new sim arriving tomorrow from EE and will obviously want to initiate a number transfer right away. Am I likely run into issues here? I.e. am I going to get lumped with a huge bill before the phone has arrived and the return processed?
I did ask live chat, they didn’t particularly understand the issue.
Okay @Kashinoda, you need to wait until your cooling-off period return has been processed by iD Mobile.
When iD process your return, your iD account (set-up for your new network connection) is converted from pay monthly to PAYG. Once your iD account becomes PAYG, you can get a PAC to switch (the number you want to keep) to another provider.
  • 12347 replies
  • May 2, 2024
  • May 2, 2024
Thanks @andewhite, so basically keep using the ID sim until it flips over. Works for me.
Will I need to request a new PAC code at that point?
  • 12347 replies
  • May 2, 2024
Your current PAC is valid for 30-days (expires 31/05/2024 it seems), @Kashinoda
Should iD Mobile process your return efficiently, you might be able to use the PAC you’ve got.
  • May 4, 2024
Hi @Kashinoda,
Please let us know if you have any issues with the PAC or return and we can help.
Just get back to us here and we can PM you if required.
glossy23
  • August 20, 2024
I am changing to Vodaphone in a few days.  Please could you send my my Pac code, then I can keep my numbers?
glossy23
  • August 20, 2024
My mobile number is:  [REDACTED]
  • 8369 replies
  • August 26, 2024
Hi ​​​​​​ @glossy23
glossy23
  • August 26, 2024
All sorted now, but thanks anyway 🙂
  • September 20, 2024
Hi ID Team,
I’m Leaving ID Mobile and can you cancel my Contract please. Can you supply my PAC Code also please.
Many thanks,
Archie Milanes
[REDACTED]
Hi ID Team,
I’m Leaving ID mobile, can you Cancel my Contract immediately please and can you sen me my PAC Code so I can keep my mobile number [REDACTED]
Many Thanks,
Archie Milanes
[REDACTED]
  • 8369 replies
  • September 24, 2024
Hi @Amilan2525
Please don’t post your personal information on the public forum.
