We are in Santorini now the data is working OK 👍 but when you try and make a voice call everything it's diverted to an answering machine any advice appreciated thanks 😊
Making calls in greece
Okay
Data roaming and SMS text messaging can work even when you can’t make calls - there might a network fault in Greece.
The iD roaming partners in Greece are Cosmote (T-Mobile), Vodafone, and Nova.
Reply.
