Making calls in greece
  • September 10, 2024
  • 11 replies
  • 120 views
We are in Santorini now the data is working OK 👍 but when you try and make a voice call everything it's diverted to an answering machine any advice appreciated thanks 😊
Okay @Anne2705, are you having trouble calling UK or Greek mobile numbers, or both?
Data roaming and SMS text messaging can work even when you can’t make calls - there might a network fault in Greece.
The iD roaming partners in Greece are Cosmote (T-Mobile), Vodafone, and Nova.
  • 12459 replies
Does this happen with landlines only, mobiles only, or both, @Anne2705?
Are you calling UK or Greek numbers, or both?
Did you get a roaming rates message from iD Mobile when you arrived in Santorini?
Mobiles! yes we had a message . But is it possible just to get roaming?
  • 12459 replies
English mobile numbers.  Are a problem.  Thanks for your help 👍
English mobile number in greece
  • 12459 replies
You may need to manually select another one of the Greek roaming networks, @Anne2705
Not sure if all 3 provide coverage on Santorini though.
  • 4825 replies
  • September 11, 2024
Hi there @Anne2705, welcome to Community!
We hope the kind advice from @andewhite has been able to help thus far.
Can you confirm if you’re still having issues making calls back to the UK please?
  • September 12, 2024
Still can't make calls thanks for your help 🙂
Tom B
  • 8434 replies
Hi @Anne2705
Don Eley
  • October 13, 2024
Going to rodes
Tom B
  • 8434 replies
  • October 14, 2024
Hi @Don Eley
Sounds nice, do you require any assistance with anything?
