We are in Santorini now the data is working OK 👍 but when you try and make a voice call everything it's diverted to an answering machine any advice appreciated thanks 😊
Making calls in greece
Okay
Data roaming and SMS text messaging can work even when you can’t make calls - there might a network fault in Greece.
The iD roaming partners in Greece are Cosmote (T-Mobile), Vodafone, and Nova.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
