Maria
Maria Pender Hobday
I am in the US and not receiving a code by txt to log into my account to setup data roaming? How else can I log in?
Maria Pender Hobday wrote:
Have tried connecting manually, it's says connected to a each network and signal is showing as on roaming, but when trying to go into the internet it's says 'no internet '.
Okay @Maria Pender Hobday, your iD account bill cap might be £0, or the roaming mobile data option on your handset maybe turned OFF.
Roaming mobile data in the US is quite pricey - iD charge for this at £0.30/MB.
So for example:
  • Using 10MB/day = £3/day.
  • Using 100MB/day = £30/day.
  • 12167 replies
  • May 16, 2024
Roaming is normally on by default for your iD account, @Maria Pender Hobday?
Did you turn this off before you arrived in the USA?
  • 3853 replies
  • May 21, 2024
Hey there @Maria Pender Hobday, welcome to Community!
As @andewhite has politely mentioned, roaming is normally turned on via default on your iD Mobile account, or can be switched on via logging into the iD Mobile app/website. You will also need to ensure you’ve enabled roaming via your phone’s own settings, as well as increasing your bill cap via the iD Mobile app/website, to allow for charges to go through, and to an amount you’re happy spending.
If you’re still having issues with receiving the verification code, or turning roaming on/off, please let us know, and we can discuss further.
Maria Pender Hobday
Hi, I have turned on data roaming on app and phone, upped my bill to accommodate roaming but I'm still not getting roaming? What else can I do it's a bit of a problem with no data.
  • 8225 replies
  • May 23, 2024
Hi @Maria Pender Hobday
Are you getting any roaming or is the issue just with receiving the text?
Are you able to manually connect to either AT&T and/or T-Mobile?
Maria Pender Hobday
I'm receiving texts , still am not getting any data! My phone is showing the roaming signal/sign, it's just not connecting.
I'll try manually connecting to AT&T or T-Mobile.
Thank you.
Maria Pender Hobday
  • 12167 replies
  • May 23, 2024
So for example:
Maria Pender Hobday
No I have data roaming in on my phone and if app and have upped my bill cap. Still no internet.
  • 12167 replies
  • May 23, 2024
How long have you been using the same iD SIM card, @Maria Pender Hobday
Sometimes very ‘old’ SIM cards seem to cause problems.
Maria Pender Hobday
It was a brand new SIM Feb/March this year.
  • 12167 replies
  • May 24, 2024
Are you using a VPN or Private DNS, @Maria Pender Hobday
Are you using more than one SIM in your handset?
