mast in dn350pw down again!!
Why is the mast down again in postcode dn350pw how can there be problems over and over again!
stupid!
  • 8613 replies
  • June 23, 2025
Hi ​@Kev26483
I’m sorry to hear this, taking a look Three UK are aware of this outage and are working on a fix, apologies for any inconvenience caused.
How long have you had issues this time in this area?
  • June 23, 2025
It’s been like this quite a few times now over the last few weekends
  • June 23, 2025
Worst thing is there is no customer service to report it to apart from here but when you have no signal how can you ..?
  • 5587 replies
  • June 24, 2025
Hey there ​@Kev26483, sorry to hear that, we hope this is resolved ASAP.
In terms of contacting us, we’re contactable here, via our live-chat and via our socials.
  • June 24, 2025
Can you check postcode s703pb signal is shocking again
  • 2349 replies
  • June 24, 2025
Hi ​@Kev26483
We have checked and there are no reported issues in S70 3PB.
Are you using 4G or 5G to connect?
Natalie
  • June 24, 2025
Using 4g and yes it’s showing as fine but it’s deffo not fine
  • 2349 replies
  • June 24, 2025
Thank you.
Are you able to perform a manual network reset whilst in the area?
Natalie
  • June 24, 2025
That means losing all my passwords for wifis etc..! Shouldn’t have to, this is stupid
  • 5587 replies
  • June 26, 2025
Hey there ​@Kev26483, we appreciate that, however, this could help resolve the issue, and we need to do all relevant troubleshooting to try and assist you as best as possible.
