I’ve just setting up my phone and I’m confused as to which setting I should use. What exactly are primary and travel? How do I use them?
mobile data settings: Off - Primary - Travel
Best answer by Matthew T
Morning
Sounds like you’ve got multiple SIMs in your phone. The default names are Primary and Travel, but they don’t make a difference to how the SIM functions. If you don’t want multiple SIMs, please remove the old SIM from the phone.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
