mobile data settings: Off - Primary - Travel
I’ve just setting up my phone and I’m confused as to which setting I should use.  What exactly are primary and travel?  How do I use them?
Best answer by Matthew T
Morning @Bluecheese,
Sounds like you’ve got multiple SIMs in your phone. The default names are Primary and Travel, but they don’t make a difference to how the SIM functions. If you don’t want multiple SIMs, please remove the old SIM from the phone.
  • 1861 replies
  • July 22, 2024
  • September 11, 2024
Hi I have the same situation and only have the new ID sim in my phone. Primary line will not work. All numbers in my phone are saved as primary and so I have the change to travel to make a call
  • 8225 replies
  • September 12, 2024
Hi @Id52444
I’d recommend the above from @Matthew T, or we’d recommend speaking to Apple directly for support on swapping the labels for SIMs in your device.
