Mobile phone unable to make or receive calls
  • September 12, 2024
  • 96 views
Stuart Currie
I have two mobile phones on my account with id mobile, my phone has a 4G Sim, my wife’s has a 5G Sim.
We have never had any previous issue with our mobile phone service.
Yesterday 11/09/24 my wife informed me that she was unable to make or receive calls from her mobile.
My phone is working fine it has a 4G Sim, my wife has a 5G Sim.
She still has internet access, emails are working , text messages , Whatspp etc are all fine and working as normal.
I tried all of the suggested solutions, reset the phone , checked and removed the Sim, nothing has changed.
We have not altered any of the phone settings. Is there a problem with the 5G Sim ? any advice would be gratefully received. Failing this a trip to Currys may be required.
Best answer by Tyler C
Hi there @Stuart Currie, welcome to Community!
We're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know or contact us via our live-chat:
Have you also tried some of the troubleshooting methods below?
https://community.idmobile.co.uk/troubleshooting-177
  • 5513 replies
