My device won't charge
  • November 14, 2024
  • 50 views
Les McMillan
My red I xiomi note will not charge
Daz_S
  • 1627 replies
  • November 14, 2024
Hi there ​@Les McMillan
The first thing to try is another mains socket, just in case the one you’re using has developed a fault.
Then try another usb cable and/or mains charger of the same voltage and output capacity (ie 2000mAh).
If you’ve proven that the mains socket, charger and cable are ok then inspect the charger port on the phone, does it lock intact with no debris in there?
After you’ve confirmed, to the best of your ability, then assuming how old the phone is (less than 12 months old) and it was purchased direct from iD, it would be advisable to pop it down to your local Curry for them to have a look at it.
  • 4825 replies
  • November 14, 2024
Hey there ​@Les McMillan, sorry to hear that.
How long have you had the phone?
Did you purchase it via iD Mobile, Carphone Warehouse etc?
