when i call someone its not showing my number to them. They are see it as unknow number when i make calls to someone. Can you please let me know what settings i have to update so that my true caller number is displayed to others when i make calls ?
my phone number is shown as unknow to others
You should be able to change the mobile number on your set in the settings of the dialler / phone app,
Perhaps your handset hasn’t detected the mobile number from the service provider?
Log in to the iD Community.
Social Login
