network provider voicemail - call
  • August 7, 2024
  • 2609 views
iPhone 12
I have a message which says “network provider voicemail” with a call button next to it. How do I get rid of it. I have pressed the button a got through to voicemail and expected the message to disappear but it hasn’t. Should it?
Many thanks
  • 8408 replies
  • August 14, 2024
Hi @Natsp
Please could you share a screenshot of the message you’re seeing?
(Blocking/blurring any personal information that may show)
  • August 14, 2024
Morning Tom, thank you for the reply, please see below.
  • August 20, 2024
Hi @Natsp,
Please can you try and switch your voicemail on and off again?
It may also be worth resetting your network settings to see if that makes a difference.
