There has been no data coverage on ID mobile in Whitehaven town for several weeks now? Call coverage is patchy as well. Service checker has said there is an issue you are working on for a number of weeks but no further details.
Can you let us know what is going on and when it will be fixed? If this is long term, I will need to change provider.
No data. overage in Whitehaven CA28?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
