No incoming calls when roaming, failed port?
  • February 22, 2025
  • 41 views
Andy Edwards
I have recently joined ID and ported my number from Talkmobile. Everything seemed fine until I was roaming in Europe. I can make outgoing calls and data works fine, but incoming callers are met with the message ‘This number cannot accept your call’.
The issue is not handset related, I travel for work and fully understand how to set up my phone for roaming and have been through troubleshooting with CS on a live chat. This was escalated to the Technical Team who got back a day later and suggested changing my network selection from automatic to one from a supplied list. I’d obviously tried this already, and am quite frustrated at the poor support offered and lack of a number to call.
Could this be due to a partially failed port? If so, what steps should I take to resolve this.
Any help would be greatly appreciated.
  • February 24, 2025
Hello ​@Andy Edwards
We are very sorry to hear of the issues you have been facing with the service whilst roaming.
Can you please confirm which date the port took place on and what handset you are using?
Nat
