no signal and network problem
  • 10 February 2024
  • 9 replies
  • 333 views
Iuliana1997
Hi!! I have 3 hours now since I can’t use the internet or the phone to make calls.I tried to use the app and also is not working.What is this?
Best answer by WelshPaul
Some customers may still be experiencing intermittent issues with the network. Their engineers are working hard to fix it and they apologise sincerely to the inconvenience this is causing.
  • 2452 replies
  • February 10, 2024
Debd
  • February 10, 2024
Clearly this issue has not been rectified I've had no mobile data or calls for 3 days.  What's the point of a mobile phone if you can't connect to the network!!
David Baker
  • February 10, 2024
Please can you tell us what's going on? When will this be fixed?
David Baker
  • February 10, 2024
@WelshPaul do you work for iD?
  • February 10, 2024
Both my partner and I just got our signal back in Sheffield after several hours.
  • February 12, 2024
No network can’t make a single call what’s going on
  • 7579 replies
  • February 12, 2024
Hi @Iuliana1997, @Debd, @David Baker, @KoalaKub & @Rubel123
Hey there, we're very sorry for any disruption, we are aware of the issue/outage and we are currently working on this as a high priority. We hope to have this resolved as soon as possible. Thank you for your patience with us.
https://community.idmobile.co.uk/announcements-16/service-update-network-issue-and-problems-accessing-the-id-app-58108
Murdie Ross
  • February 12, 2024
Have not been able to phone or receive calls for 8hrs now
  • 7617 replies
  • February 14, 2024
Hi @Murdie Ross,
Are you still experiencing the issue?
It may be worth restarting the handset or resetting your network settings to see if that gets calls working.
Some customers are still having issues with 3G calls which is being worked on.
