No signal at all
  • November 16, 2024
  • 84 views
Beata Rusiecka
I'm on Rugby Stadium in Edinburgh and guess what, no signal at all, such a BAD network. Im using my Partner data from Lyca mobile and work great. Shame on you ID mobile, no signal in place like this, horrendous🤦🤦🤦
Best answer by Lauren
Hi ​@Beata Rusiecka, I’m sorry to hear that.
We use 3UK for our signal. Lycamobile uses EE.
It’s possible that there is an outage via 3UK at this post code. You’ll be able to check for any signal degradations/overall coverage via the link below:
Check your network coverage | Support | Three
-Lauren
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • November 16, 2024
-Lauren
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 16, 2024
Assuming you must be at Murrayfield, then this is the postcode - EH12 5PJ ​@Beata Rusiecka
Then if so Three are aware of an ongoing issue (iD piggyback on Three)
We're fixing an issue in this area at the moment and aim to have things back up-and-running as soon as possible.
We're sorry for any disruption this may cause and will add any further updates here.
Now I’m not one to ever defend iD, but technically this isn’t their fault.
Anyway, enjoy the game!
