Normal Text Messages and Data Usage
  • October 8, 2024
  • 6 replies
  • 100 views
Si Lawtz
I switched from 3 to ID mobile a couple months ago and have a couple issues - I wondered if anyone else has had the same.
The first is that there seems to be an issue with my normal text messages (not WhatsApp). If I try to send one it says message could not be delivered but in fact it seems like that are getting to the person so I don’t know why it says they arent. Also I tested by texting my wife and for some reason it arrives under a different phone number (I think it is the one ID Mobile gave me, but I brought my old number across from 3).
The second is a concern over data usage. When I log in to the ID mobile app it says 85.5GB / 50GB which suggests to me my limit is 50GB but somehow I’ve used an extra 35.5GB? Which presumably I’ll be charged for?!
Thanks!
Si Lawtz wrote:
Thank you. I’m on iPhone. I’ve tried to turn off sim out method but no joy! Appreciate the data usage advice!
Have you checked the number shown in Settings > Phone > My Number is correct, @Si Lawtz
This iD community article might help.
  • October 9, 2024
Hi si, data carries over if you haven't used it so I'd guess it's telling you that you have 85.5 GB still to use. Mine does the same.
With the sim issue, I'd try and take it out and put it back in and restart your phone. If that doesn't work you probably need to speak to someone from ID
  • 8369 replies
  • October 10, 2024
Hi @Si Lawtz
Are you on iPhone or Android?
In terms of your data issue, @jessiieeea is right, the extra on top of 50GB is your data rollover, so not something you’re being charged extra for.
Si Lawtz
  • October 10, 2024
  • 12341 replies
  • October 10, 2024
  • May 17, 2025
Tom wrote:
Hi @Si Lawtz
If they would show total usage per month and rollover it would be very helpful…..
Suspect their reasons for not doing so!
Forum|alt.badge.img+21
  • 2216 replies
  • May 19, 2025
Hi ​@Si Lawtz
Thank you for getting back to us.
Can you please take a look at the link provided by ​@andewhite and let us know if this helps?
Natalie
