I've not been able to make or receive calls or txt messages for the last 2 weeks. Done the upgrade but still nothing.
Using Samsung galaxy phone.
Best answer by Lauren K
You can also check if your phone is compatible with iD 4G calling via this link:
What phone can I use with the iD Mobile Network? | iD Mobile Network
-Lauren
