not received otpc call from banks ,goes straight to voicemail
Calls for otpc from go straight to voicemail, asked ID about this before and got fobbed off. Text otpc come through but not calls
Still an issue
Best answer by Tyler C
Hey there @H22, we’re sorry to hear that.
In that case, we’d recommend contacting our live-chat who can investigate this further for you and raise this to our technical team:
  • 4541 replies
  • June 11, 2024
Hey there @H22, welcome to Community!
When you call them, does it ring at all, or simply ends as soon as you attempt the call please?
  • 15 replies
  • June 11, 2024
It's when they call me, the phone doesn't ring at all. Goes to voicemail or just fails
Tom B
  • 8408 replies
  • June 26, 2024
Hi @H22
Okay, are you receiving other normal calls?
Is it just the bank?
  • 15 replies
  • June 26, 2024
Just banks , the building society and NS&I . Every other phone call comes through. It's when I have to get a two stage  security code set to my phone,ie a pin number to gain access. Some organisations send a text which works perfectly but not when they ring
  • 4541 replies
  • June 28, 2024
  • 15 replies
  • August 12, 2024
Just tried again with my bank and guess what ,my phone never rung. Had to rely on the landline yet again
Tried to follow you advice and go to live chat and once again ID mobile are shocking in their customer care department and it's not available.
I'm going to log a complaint now ahs this is an issue I was told would be fixed after a few hours when I first took out my ID contract.
You clearly don't honour your word and it's impossible to get a solution to my problem
Tom B
  • 8408 replies
  • August 19, 2024
Hi @H22
Sorry to hear that, we’d recommend continuing with your complaint if you’ve raised one already.
  • 15 replies
  • August 19, 2024
I've raised the issue yet again and I'm still waiting for a reply from ID . They said 48hrs but I'm still waiting nearly a week later.
Tom B
  • 8408 replies
  • August 26, 2024
Hi @H22
