not receiving calls
Can you tell me why I’m not receiving calls please
Best answer by MZone
Check the service status here for any issues in your area.
MZone
  • 1207 replies
  • February 3, 2025
Forum|alt.badge.img+21
  • 2255 replies
  • February 4, 2025
Hello ​@Elephanttrunk
We are very sorry to hear you are experiencing issues receiving calls.
Can you please check and confirm the following?
  • The Service Status page here
  • Have you recently ported a number in to iD Mobile?
  • What is the make/model of your handset?
  • Are all calls impacted or calls from certain numbers?
  • Is the data and text service working?
Nat
I am not getting all my calls. The phone does not ring but goes to voicemail. I also get cut off during calls. Getting to the point where I will have to change network/supplier. So frustrating  and scary as I live alone
  • 4297 replies
  • April 16, 2025
Hey there ​@richard pendle, we’re sorry to hear that. What phone do you have and what’s your full postcode?
Is it only calls affected? Can you make calls?
I have a Samsung a25. I am nr32 5ha. The phone is only a few months old. My old Samsung seems to have better reception.
Siân
Forum|alt.badge.img+8
  • 1323 replies
  • April 16, 2025
Thanks ​@richard pendle
We can’t see any issues with coverage in that area right now, it should be great!#
Have you tried the SIM in your old handset and it works better? That may suggest it is an issue with the handset itself.
I can make calls but they often cut out.
  • 8408 replies
  • April 17, 2025
Hi ​@richard pendle
Okay, how long have you had this issue?
Have you tried a network settings reset?
Thanks for your help. Yes I tried a reset. I think there is a consistency issue with the network as both phones vary in the numbers of bars throughout the day by a lot, even if they are used in the same place. My husbands older Samsung does seem to be better than my a25. Shame I didn't know this would be an issue when I bought it.
  • 4297 replies
  • April 18, 2025
Hey there ​@richard pendle, sorry to hear that.
Would you be happy to try a replacement SIM card?
