My phone won’t receive incoming calls or make outgoing calls as of this morning
not receiving incoming calls or making outgoing
Best answer by Matthew T
Morning
We’re currently experiencing a technical issue that means some customers may be unable to make or receive calls. Please refer to the link below for the latest updates:
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
