Nothing Phone 3a Wifi Calling
I’m potentially looking to switch to ID mobile simply for the reason that they seem to support Nothing Phones for Wifi Calling. My current provider doesnt. Does anyone know if the Nothing Phone 3a does work with Wifi calling yet as I am aware its not listed as one currently.
Best answer by JoeKing
@Chaza96  I've used the 3a on ID Mobile and it works a treat so does My Nothing Phone 2 on WiFi calling
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 372 replies
  • May 8, 2025
@Chaza96 I simple Internet search would of given you the answer. Yes it does have and support wifi calling.
Joe
  • 2897 replies
  • May 8, 2025
Officially, it’s a no because it’s not on the supported device list. However, the Nothing Phone 2 and 2a are.
  • May 8, 2025
Joe
Hi Joe
Yes I am aware the phone does WiFi calling already. It's whether this network supports this make and model...
  • May 8, 2025
Thanks Paul
I saw the 2 and 2a were present does bode well and it seems ID are the only ones with nothing phones even listed! Just wondering if anyone in the forum has a nothing phone 3a
  • 8352 replies
  • May 9, 2025
Hi ​@Chaza96
As ​@WelshPaul & ​@JoeKing suggest, officially it’d be a no, this doesn’t mean it wouldn’t work, but that we can’t officially say or suggest it would.
As for an iD Mobile x Nothing Phone 3a user, fingers crossed one sees this and reports back.
JoeKing
Silver Contributor
  • 372 replies
  • May 9, 2025
  • May 9, 2025
Thanks for confimring that you’ve had a 3a working with them! appreciate it!
