number not migrated over correctly ,
  • September 7, 2024
  • 32 views
Sharon Beattie
When I text someone it’s coming up the number ID assigned to phone before my old number migrated over to my new phone
Best answer by Tyler C
Hey there @Sharon Beattie, welcome to Community!
Please try the following for whichever type of phone you have:
For iPhone:
For Android:
Alternatively, you can turn Chat Features/RCS off and test SMS after this
Please also try restarting your phone.
  • 5291 replies
  • September 10, 2024
For iPhone:
For Android:
