number not transferred
i believe i have submitted my PAC code but number hasn’t transferred. Is there anyway of checking
thanks
Will R
  • 4103 replies
  • June 22, 2021
Hi @Emma2540,
When was it you submitted the request sorry?
Will
  • June 22, 2021
thanks ported across this afternoon 👍🏻
  • 9 replies
  • June 22, 2021
I”m on the same boat.. just moved from another network this pm and have no way to finding out when my number has been transferred.
I installed the app in my phone but it tells me my user name doesn’t exist.. even tho I’m logged in on the pc..
went to change my password just in case but still the App won’t recognise my user..
  • 3080 replies
  • June 23, 2021
You might find this post helpful. 👍
Mohammed H
  • 7962 replies
  • June 23, 2021
Hello @TorresNM you can use the “forgotten your username” tool to recover your username.
Just a note, the iD Community and the iD Mobile app/account are 2 separate accounts so registering for the Community to post here has no link to your actual iD account for managing your plan as this is just a forum for discussion.
You advised you just submitted it this PM? so if it was submitted on the 22/06/21 before 6PM it’ll process for today and if it was after 6PM it’ll process on the 24/06/21.
