Hi, I successfully set up my new sim and transferred my old number to it. However, after 24 hours, my number is still failing to be verified by Apple to connect it to my iMessages and FaceTime. I’ve done everything to resolve it and spoke to Apple who also have tried everything but the problem still persists. Apple suggested if it continues, to inform you and get a reference number so they can check if everything is ok your end before proceeding forward to engineering. Any support would be great.
Number not verifying
Best answer by hazmilly1234
I worked it out…I switched on my iPad and by signing out of my Apple id on my phone, Apple wanted me to verify and agree to using my number on my iPad, as this was the only device on my Apple ID. So, the reason my number was verifying whole time and not connecting to iMessage and FaceTime , was because it wanted me to verify it on my iPad which I happened to have on at the time. It was just by pure chance I discovered this - worked instantly. Seems with multiple device accounts, Apple verifies any number changes using the other devices.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
