old number hasnt switched over
I requested to keep my old number when I switched from Vodafone to id mobile on 06/06/24. But when I ring or message people it comes up with the new number that I don't want. So many people have my old number that id like to keep as requested could this be sorted please?
Best answer by Tom
Hi @Adele_94
I’d recommend the following;
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
  • 4228 replies
  • June 19, 2024
Hey there @Adele_94, all port’s complete between 8am-10pm on the selected date.
Please let us know if there are still any issues.
  • June 20, 2024
It still shows a number I don't want to show when I message people 😫
  • 12353 replies
  • June 20, 2024
Have you tried a NETWORK RESET on your device, @Adele_94
The handset user guide should explain the reset procedures.
  • June 20, 2024
How do I do that please?
  • 12353 replies
  • June 20, 2024
Okay @Adele_94, perhaps Google “NETWORK RESET” for your handset, or look at your handset user guide, which should explain the reset procedures.
  • 8408 replies
  • July 5, 2024
Hi @Adele_94
