old phone number has transferred for incoming calls but not outgoing
Hi, my phone number has transferred for incoming calls but not outgoing calls or messages. Also I can’t save when I change the number in settings. Please help!
Best answer by Kash M
Hi @rebeccafrost1,
Depending on if you are using Android or iPhone please try the below:
For iMessage Messages, please try the below:
For Android:
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
In regards to the number for calling, please can you remove the SIM for a few minutes whilst the handset is off.
You can then restart the handset with the SIM in and reset your network settings. Hopefully this should allow you to update the number.
  • 12540 replies
  • May 31, 2024
When was your switch scheduled to take place, @rebeccafrost1
  • 8256 replies
  • June 5, 2024
Hi @rebeccafrost1,
For Android:
