one ui7 beta
  • 10 replies
Hi just wondering if anyone is on one ui7 beta version and having trouble getting the stable version as my s24 ultra has a glitch with the beta version and I've been told to get intouch with my carrier
Best answer by WelshPaul
Try asking over on the Samsung community forum.
https://eu.community.samsung.com/t5/galaxy-s24-series/bd-p/galaxy-s24-uk
  • 4760 replies
  • May 14, 2025
Hey there ​@Rob437, can you explain what issue’s you’re having with which device?
  • 3078 replies
  • May 14, 2025
You shouldn’t be using beta software unless you’re a developer and/or you know what you’re doing. Installing beta firmware can also invalidate any warranty or result in refusal when requesting a paid repair service.
  • 10 replies
  • May 14, 2025
HI the one ui7 beta is there for samsung members to try and report any issues back to samsung so they can fix any bugs or glitchs you don't have to be a developer to use it
  • 10 replies
  • May 14, 2025
HI I've got the s24 ultra the beta program is for anyone to use then after the program has finished it automatically goes to the stable version but for some reason mine is stuck with a glitch so I'm asking different people if they have had the same problem and what they did to fix it
  • 3078 replies
  • May 14, 2025
Siân W
Forum|alt.badge.img+13
  • 1376 replies
  • May 15, 2025
Hi ​@Rob437  as  ​@WelshPaul  has mentioned, it may be worth checking on the Samsung forum, hope you manage to get it sorted!
