BEEN TRYING TO GET PAC CODE [REDACTED] , KEEP GETTING GENERIC TEXT
ALL I WANT IS A PAC CODE
PAUL MCNALLY
PAUL MCNALLY
Best answer by Lauren K
If the PAC code isn’t coming through via text, you can also request your PAC via the iD app/your account online.
https://www.idmobile.co.uk/help-and-advice/leaving-idmobile
If this method doesn’t work, the iD live chat can also source your PAC code for you.
If you type into the chat box ‘speak to an agent’ or select this option, you’d be put through to a live advisor.
Live Chat Support | iD Mobile Network
-Lauren
