PAC Switch Didn't work and calls not working
  • January 8, 2026
  • 201 views
I signed up for id mobile at the weekend and downloaded the esim. It was added as a second line.
My PAC transfer happened yesterday and I removed my O2 Sim. The id esim then became the primary sim.
Data works, but it is not showing a number and I have no access to phone calls and texts.
To make things worse I have had no update from id about what is happening with this transfer and when I try to log into the app it sends me a text message to verify my identity … but I can’t receive text messages!
There doesn’t seem to be any way to contact help and support except for here and the chatbot is completely useless.
I don’t really know what to do, but this has been a very frustrating and disappointing start to using id mobile!
    It’s up to you to configure the device correctly. What phone do you have?
    daz4126Author
    How am I supposed to ‘configure the device correctly’? The email said the PAC transfer would just work.
    It’s an iPhone 11
    daz4126Author
    I think the sim was in data only mode when it was activated, so won’t use voice. Is there a way to reinstall the esim?
    daz4126Author
    It’s just suddenly started working, not sure what the problem was, maybe the switch just took longer than they said?
    Hi, ​@daz4126
    Thank you for getting in touch with us, I’m really sorry to hear about the problems you’re experiencing following your recent sign-up and PAC transfer. I completely understand how frustrating this must be, especially when you’re unable to make or receive calls or texts.
    From what you’ve described, it appears that while your data service is active, the number transfer and full activation of your eSIM have not yet completed. This can occasionally happen during a PAC transfer, and it may take a little additional time for calls and texts to become fully provisioned.
    I also appreciate how difficult this has made accessing the app, as the verification text cannot be received at the moment. I’m sorry for the lack of updates and for the inconvenience caused when trying to reach support. I am glad that now all your services are working.
    Zandile
    The iD Mobile Team
