PAC transfer not 100% complete
  • May 19, 2024
  • 256 views
Hi there,
Did a PAC transfer a couple weeks ago and all good from a WhatsApp/phone call point of view.
However when sending text messages it's showing to others as my original account phone number and not my old number that I've transferred too (so a different number if a call to text), so is causing confusion when texting.
Any help?
Best answer by Tom
Hi @Rjones57
I’d recommend the following;
On iPhone;
On Android;
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
  • 8352 replies
  • May 22, 2024
Hi @Rjones57
On iPhone;
On Android;
