Why can’t I use my pc to log in to Id Mobile. My phone app has stopped working now as well. Is everyone OK there?
PC connection
Best answer by Michelle H
We are sorry to hear about the issues you are facing.
Are there any error messages when you are trying to log in?
Please could you uninstall the app from your device and reinstall the app?
Michelle
iD Mobile
Log in to the iD Community.
Social Login
