When my phone is is "resting", it displays emergency calls only. Yet I can make calls.
Why is that?
Why is that?
Best answer by WelshPaul
Then your phone is receiving a signal. As to why your phone is showing an exclamation mark or displaying “emergency calls only”, try asking Oppo. In the meantime, maybe try a SIM replacement.
