Phone Displaying Emergency Calls Only
When my phone is is "resting", it displays emergency calls only. Yet I can make calls.
Why is that?
Best answer by WelshPaul
Then your phone is receiving a signal. As to why your phone is showing an exclamation mark or displaying “emergency calls only”, try asking Oppo. In the meantime, maybe try a SIM replacement.
  • 3099 replies
  • June 22, 2025
If “emergency calls only” is displayed, then it’s likely you have no signal. The reason you’re still able to make and receive calls is probably because you have Wi-Fi calling enabled.
  • 18 replies
  • June 22, 2025
Don't think I have WiFi calling. Just searched my settings for WiFi calling and it wasn't found.
Puzzling.
  • 3099 replies
  • June 22, 2025
What phone do you have?
  • 18 replies
  • June 22, 2025
Oppo A15
  • 3099 replies
  • June 22, 2025
The Oppo A15 supports Wi-Fi calling, but the exact steps to enable it may vary depending on the carrier and device settings. According to a discussion on the O2 Community, users have found that Wi-Fi calling can be enabled by navigating to "Settings > Wi-Fi and Internet > SIM and Network" and then toggling the Wi-Fi calling option for the respective SIM slot.
  • 18 replies
  • June 22, 2025
Found that and it's set at on. So, that explains it!
  • 18 replies
  • June 22, 2025
Just tried making a call with WiFi calling turned off, and it still worked.
  • 3099 replies
  • June 22, 2025
  • 18 replies
  • June 22, 2025
Phone's doing what I need it to do.I was just curious why it was displaying emergency calls only.
Thanks for your time and efforts.
  • 8552 replies
  • June 23, 2025
Hi ​@Michael Duffy
Definitely a strange one, a replacement SIM card could be worth a shot.
Thanks for the help here, ​@WelshPaul.
  • 18 replies
  • June 23, 2025
It's not really a problem, phone works perfectly despite the emergency calls only. I'm just wondering if there's other id mobile customers in the Glasgow area that are getting the same m message.
  • 5247 replies
  • June 24, 2025
No problem ​@Michael Duffy, thank you for letting us know. Let us know if you need any further assistance.
