Phone not ringing out
  • February 28, 2025
  • 52 views
Lola Olajide
My Nokia G20 has not rung out for the past few days. I have put it off and on a few times and checked the settings. It is not in silence or on an aeroplane. Is anyone experiencing this?
Hi ​@Lola Olajide
Can you receive calls, send/receive texts and use your data?
Do you have VoLTe enabled on your phone
To enable VoLTE on a Nokia G20, you can do the following:
  1. Go to the Start screen
  2. Swipe up to open the Menu
  3. Select Settings
  4. Select Network & Internet
  5. Select a SIM card
  6. Select Advanced
  7. Scroll down and enable Data during call
  8. VoLTE is now enabled
Have you checked to see if there is any maintenance in your area or the coverage?
Once you checked all of these then you will need to talk to an advisor via Live Chat …..
Type ‘talk to a person’ in the dialect box to bypass the inane questions.
Just be aware that chats may take a while to open/repsond as they are chatting to other customers and you will be one of many.
Good luck x
  • 5587 replies
  • February 28, 2025
Hey there ​@Lola Olajide, we’re sorry to hear you’re having issues with calls.
This is likely due to the 3G turn off that began rolling out recently. You can check if this is the case in your area below:
If you have one of the phones from the below list, then 4G VOLTE and Wi-Fi calling should be able to be selected and work, and calls should still work:
If the issue persists after following the troubleshooting above and confirming if your phone is approved, then please let us know here so we can investigate further. If your phone isn't listed above, you'll need to upgrade/get a new phone I'm afraid to receive calls. Texts and data should continue to work either way.
Decembersangel72
Gold Contributor
Forum|alt.badge.img+14
Hi ​@Lola Olajide
  3. Select Settings
  6. Select Advanced
Good luck x
Lola Olajide
  • March 1, 2025
Thank you so much. My “ VOLTE” was off. I have put it on now and viola, the ringing out was restored. So happy.
Decembersangel72
Gold Contributor
So glad ​@Lola Olajide  that I could help x
  • 8256 replies
  • March 2, 2025
Hi ​@Lola Olajide,
Glad to hear that ​@Decembersangel72 resolved your issue.
If you require further assistance, please get back to us.
