phone number is incorrect
My correct phone number is this [REDACTED].
And you mentioned this number which is wrong [REDACTED].
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 381 replies
  • April 1, 2025
@Maaz3761  Please edit you post by removing your phone number's.
are you porting your number from another network to IDMobile?
If so did you get a confirmation to say  when they'll do the port?
https://www.idmobile.co.uk/switch
Joe
  • April 1, 2025
Yes I want to switch my number to ID mobile,
MZone
  • 1207 replies
  • April 1, 2025
JoeKing
Silver Contributor
  • 381 replies
  • April 1, 2025
@Maaz3761  Please edit your original post by removing your phone number's this is to safeguard your privacy.
To do so go back to the original message scroll down you'll see 3 dots to thr far right of thr thumbs up and quote symbols. Once you click on the dots an edit option will open, just edit  message and mace sure to Save the edit message.
Please check your junk/spam folder of your e-mails as you should of received an email with details of your port to IDMobile
Joe
  • 8408 replies
  • April 3, 2025
Hi ​@Maaz3761
I’d recommend using the above linked article from ​@MZone to initiate a number transfer from your previous network to iD Mobile.
