Phone number not recognised
  • October 15, 2024
  • 127 views
I have just had my number transferred from a previous account and now when people try to call me it just says my number is not recognised. How can this be solved?
  • 4228 replies
  • October 19, 2024
Hey there @Ftnine3, sorry to hear that.
What phone do you have?
Please go into your phone settings and manually change your phone number to the correct one, then restart your phone, and see if this helps.
  • October 19, 2024
Hi @Tyler, it is the correct number that shows in my settings, have even tried a new sim card which was suggested by ID mobile but this also didn't work.
  • 4228 replies
  • October 22, 2024
Hey there @Ftnine3, thank you for the update.
Is the issue only with calls, or with texts also please?
  • October 22, 2024
Hi @Tyler the issue is with calls and texts, I am unable to receive either of them
Cheers.
  • October 23, 2024
Hi @Ftnine3,
I would advise that you contact our Live Chat Team.
The team will check it out and assist you further.
