iphone SE to switch on 17th Dec
sent a new number via the SIM SMS
Cannot find a messages link in setting to follow other advice
Not receiving or able to send SMS
Calls not happening
Need to fix asap
Calls not happening
Need to fix asap
Best answer by Natalie W
Hello
Thanks for getting in touch.
On the day of the port, it can take up until 10pm for the port to be fully processed.
If you are still having issues after this time, please do let us know and we will be happy to assist further.
Nat
