I recently upgraded to sim plan via Id app, so should I cancel my old plan and how? Cause it says it's gona renew in 9 days ,and the data is more than in my plan.When I go to see my plan is only the new one that I upgraded.Any suggestion,please?
Plan cancellation
Best answer by Siân
It does state upgrade, but if you want us to check we can
The quickest way is via our live chat on our website, or we can help here if you like?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
